are the lowering springs like skunk2 or Tein Lowering Springs or tanabe springs make the car RUN smooth? not like the nonBrand kind of springs around 60bucks or down off from Ebay.
instead of adjustable coilover with springs…?
i dont really care bout the adjustable as long as it wont make my car bounce like crazy… 2inch dropping the car is good right? yeah let me know or from what ya think is good.
I found ride quality mostly matters in the shocks… Hence why they make adjustable shocks (stiff-soft)… I had H&R Race springs and Tokico Illumina’s on my old DB1. I had it on level 3… Pretty stiff, Didn’t have much bounce if any.
And to the post above me, The springs put the car leveled, It’s just the wheel well in the back is not as tall as the front that gives it the sagging look… DB1 had this.
lowering your car will make it generally stiffer due to shorter/stiffer springs and more bumpy (though not bouncy, they’re different). as long as the shocks can successfully dampen stiffer springs.
2" drop with stock shocks aint gonna work…at least for long. I would go with a coilover kit because the spring and shock are paired with each other.
vx209da, If you were to get Ground Controls, I recommend putting them on Tokico Illuminas or Koni Yellow shocks but remember that the kit for both of those are different.
tein basic sucks,
gotta mess with spring pre-load just to lower the car.
i was never a big fan of tein basics, anything above basics are decently nice though.
i have the Koni Yellow/ Ground Control setup, using custom rates.
i had all 4 shocks set on their stiffest setting, and my spring rates were 380F/450R.
on the soft setting, the car rode amazingly. on the stiffest setting, the ride was bumpy, but definitely not bouncy. this was on a bottomed out 4" drop with stock top-hats. could’ve gotten the ground control top-hats for extra, but felt i wouldn’t have needed them.
i have heard negative things about the buddy clubs. i’ve heard they are kinda bouncy, but i can’t offer my 100% opinion on them. as i’ve never been in a car with them. so take that for what it’s worth.
when i FINALLY get the DA back on the road, i’ll be utilizing a hybrid setup.
Tein N1 full bodied coilovers using EG/DC front shock/spring setup and CRX rear spring/shock setup. Massive drop, but still maintaining a large amount of shock travel.
