Hey everyone, i’m new here and just had a couple question about an ls-v motor i’m looking to pick up. It used to be a buddies of mine, and he got into a accident, so the car has been sitting in his yard for a year or so, everything was covered, head was on, spark plugs where on, intake and exhaust manifolds where on aswell, and hood down. What would the precedures be for the start up. The other question i had was, i have a 91 gs that i’m looking to swap the motor into, i know i would need a obd-0 to obd-1 jumper harness, a obd-0 to obd-1 §§§§§ connector harness, but would running a stock gsr ecu run the car ok ? i hear the gsr ecu has to recognize the butterflies that are on the gsr intake mani, but this ls-v has an after market manifold, and gsr head with itr cams. Any feedback is highly appreciated, Thanks in advance.
Your questions have already been answered. I suggest you search. It’ll answer your questions and maybe tell you other things you haven’t thought of yet.
In short… Yes the GSR ecu will run the motor.
I’ve heard people say that it will throw a CEL for the butterflies/IABs, others say it won’t. But either way, it shouldn’t put the ecu in ‘limp mode’, so it should drive alright.
It would be best to have someone (Xenocron/Phearable/your local tuner) make you a basemap and chip/install the map in your ecu… that way you have a map that will take full advantage of the setup you have. A stock ecu is meant for a stock motor. Get a chipped ecu that is tailored more to your motor.
Startup procedures are pretty basic. Try to get some new fuel in there, new fuel filter, new oil/filter. It would be smart to do a compression test (and a leakdown test, if you’re feeling up to it) to get an idea of the health of the motor. Make sure you aren’t buying a unhealthy motor.
That’s prettymuch it.
For any engine swap it is best to do the following while the engine is out of the car:
- change timing belt, water pump, tensioner.
- check for cracked or broken hoses and replace (especially any of the ones in the back).
- replace rear main seal, front main seal, driverside cam seals
- Clean IACV
Before starting the car for the first time (obviously with new fluids and filter):
- Pull ECU harness out
- Crank the engine for a about 10 seconds for the oil to circulate. Let it sit for 1 minute for starter motor to cool down.
- Plug ECU back in
- Start the car
Thank you guys, i really appreciate it.
