Ok I am planning on getting a hi comp LS with CTR pistons (some of you have now surmised where I am getting it lol). I have a few questions regarding the setup. Posted this on another forum but the more answers the better
Bottom- B18a, Eagle H beams, CTR pistons, ARP hardware
Top - Supertech valve springs and retainers, late spec ITR cams, Ferrea 1mm oversized vlaves. Both has other things done, but these should be pertinent to the questions.
p61 ecu
THe sompression at sea level with a b16 head and ctr pistons is 12.3-4:1 with a stock head gasket. Will being at altitude (5600 ft) bring this down to a reasonable 11.5:1 or something?
Is this comression too high to run reliably? Engine will not see over 8200rpm.
SInce all we really have is 91 octane out here, will this setup be compatable (if not thrive) with E-85?
If I choose to go E-85, all I really need is a fuel pump, regulator, filter and proper injectors besides the tune?
Flamesuit on. Can I tune this all-motor with e 85 on a AFC neo?
With CTR pistons in an LS block, do I have to clay it? WIll there be piston to valve contact with late spec ITR cams and oversized ferrea valves?
I probably have more questions that I can’t think of right now. Thanks in advance!
CARL! I may have to go over on my bore to 81.5. Basically I have some wiseco hi-comp pistons 81mm and I may need to sell em to you …if you haven’t got the ctr pistons. I will let them go for 450. If that’s too much lmk… I might be able to work something. I just need to get as much as possible hehe.
They will be about the same compression ratio just lighter and more heat resistant than the ctr. Full set, rings wrist pins and the little paper that tells you what the ring gap should be.
CLAY THE MOTOR EITHER WAY.
AFC Neo you may be able to tune it… but you should really hondata it up bro, the neo is okay for non-crazy builds but you will want a little more control.
E85 is great for hicompression sh!t. the e85 is equivalent to 115 octane (110 or 105 in some places) here it would be closer to 105 as at altitude our fuel is nerfed some.
The cams imo are not that aggressive so you may or may not need cam gears…
Btw don’t hack that p61 ecu dude. bite the bullet and buy a p72 or if u have to a p28 and keep that 61 virgin. That ecu is a rare piece.
THanks for the calculator! I calclated it up and it seems high. Static comp is 13.5 AT 5500ft it drops to 12.4. It was in the red, then yellow factoring in altitude. RS ratio is 1.5x sorry I forgot.
And I keep forgetting info sorry guys. Head is a pr3, fully built. It has skunk cam gears.
As far as those pistons man I will have to pass. If I had 400 to spend its going into engine management. Thanks for the offer though. I know the afc is ghetto, but I hope to get this setup running by late spring, have some fun before I join the navy.
P61 ecus I have no problem hacking for Neptune or Hondata. I will not spend extra on another ecu when I have a perectly good one and I plan on never selling the car. EIther way I can run any setup with neptune or hondata so its all good.
As far as fuel goes I am planning on getting a walbro and DSM injectors. Not a big deal because I have an extra 61 mani with rail and stuff so if I have to mod it to fit the injectors I have a spare mint one.
Also how bad is NOT having those oil squirters? Because of this I am planning on getting an oil cooler to try and get a handle one temps at least. I also want a pcv breather system.
Thanks for the info guys! I may have to start a build thread…
