ls/vtec set up
I Have a B16A head (with all the components portflow and spoon sports) port and polish. The cams in.CTR/ ex. ITR. In the block B18A1 ls rods with .25 overs. CTR piston set. Also vtec oil pump, 62 mm throttle, 255lph fuel pump, regulator,sprockets etc…
Recently i lost the mechanic in a car accident. I need help to assembly the engine (ecu to use, wire needs for vtec activation, aditional sensors needs etc… and to set up( ignition timing, fuel pressure,Sprockets degree for each cam etc. to achieve the best horsepower, torque and et’ s.
Please write me as soon as possible
Thanks,
Frank Delgado:( CarnotCycle@hotmail.com)
