I’ve been having several electrical problems, first off I noticed my driver side window would fall of track and I took of the door panel and didn’t really do anything to it then I put it back together and my window wont go back up. And also my side mirrors wont move at all. And my last problem is the a/c I left it on defog I turn it on and it wont switch to another function. Any help would be greatly appreciated.
Check your fuses man and make sure there are all good
all fuses are good
This is a late response but check the window track mounts that are bolted to the actual glass itself. My left edge bracket is borken off and causes this problem sometimes. Check to see if they rollers has fallen apart in all the galvanized window tracks. It may be easier to pull the entire actuator out. The window motor could be dead and not allowing it to roll up as well (if it’s power window).
I think mirrors may have a relay. If not you may have to start probing with a DMM and a wire diagram.
Lastly, have you pulled your electronic climate control box out of the dash? The one where you select the function. I know these are notorious to break, usually starting with the green lights not lighting up. It’s electronic to vacuum if I recall correctly.
HTH
- Brandon
