background:
I’ve owned this car since 2003. Its a 90 RS, the lightest DA integra they made. It’s pretty much gutted to the bone, with no rear interior, no AC and no power steering.I bought it bone stock with 120k miles. It was turboed in 2005 but it sat shortly afterwards, largely unused for 3 or 4 years while I was away at school. It ran great and was very fast but structurally, the car needed many replacement parts
I pretty much had lost interest in it but last year I started to replace all the structural components such as brakes, tires, suspension, bushings, axles, wheel bearings as well as made upgrades to the car itself- boost gauge, fan, battery holder, battery, magnetic drain plugs, swaybar, coilovers w/ tophats, along many other aftermarket upgrades or OEM replacement parts.
The body of the car is pretty good. There are a few small rust spots but nothing major. The front fenders are a lil banged up but they can be had cheap. Ever since I took the time to rebuild much of the suspension and brakes, structurally the car has been very solid. This car is by no means mint condition but it runs good and handles very well. With the boost turned up, it will definitely run high 13’s to low 14’s. I keep the boost very low most of the time (only 4psi) and it still has and will run 14.7 all day long! The front windshield has a crack in it. I also have the fan wired with an interior switch. I usually flip it on when I’m in stop and go or city driving. It also throws an oxygen sensor code because I’m not running an o2 (this can be eliminated by a tuner) and also a tp sensor code. I have a spare bored out throttle body I’m including. All you have to do is get a tps.
I really would like to keep this car, especially considering all the money I just spent to make it solid, but due to reasons out of my control, I have to get rid of it. I think this would make a great project, especially if you already own a DA. Not only would you be getting a very fast, very solid and well handling car, you would be getting a crap load of very desirable extra parts for either car. With that being said, I want to sell this car and all the parts together.
I’m sure you already know but there aren’t many of these cars left on the road especially in good overall shape. In addition, since its a 1990, it’s considered historic if you decide to go that route, making state inspection in MD unnecessary. I doubt you find a 13 second car with more modifications, handling, upkeep and OG factor for the same price.
[video=youtube_share;JlKqqTih-DQ]1990 Acura DA Integra Turbo Stock b18a 10 PSI - YouTube
I’m asking $3000 or best offer.
Anyway here’s list of mods and extra parts…
engine:
had the head milled, 3 angle valve job, new headgasket, arp head studs about 6k miles ago
original block- 165k+ miles. had a compression test done a few months ago and got 210 on all 4 cylinders cold
custom turbo kit-
custom semi tubular manifold (nice thick flanges)
garrett t3 turbo .42 .48 (rebuilt 8k miles ago, little side to side shaft play)
2.5 inch stainless steel downpipe
gReddy type S BOV
custom tube and fin intercooler
turbosmart manual boost controller
2 3/8th autometer boost gauge and pod, black face, white needles matches nicely with gauge cluster (brand new)
street tuned with turboedit
skunk2 intake manifold
b&m fuel pressure regulator and gauge
walbro 255 fuel pump
thermal research and design 3 inch turbo exhaust (nice deep tone)
exedy organic stage 1 clutch
koyo racing half sized alumnium radiator w/ 1.1 bar cap
mishimoto 10 inch fan (brand new)
mishimoto upper and lower radiator hoses- black (brand new)
passwordJDM magnetic oil and transmission plug (brand new)
passwordJDM carbon fiber battery relocator (brand new)
odyssey PC680 battery (brand new)
suspension-
full-race traction bar
tokico illumina 5 way adjustable shocks
ground control adjustable coilovers with front top hats (brand new)
function form rear lower control arms (brand new)
asr racing 23mm rear sway bar (brand new)
asr subframe brace- black (brand new and limited edition)
asr spherical adjustable endlinks (brand new)
es bushing kit for front suspension peices and rear trailing arm (brand new)
just replaced all four wheel bearings (oem), lower ball joints (oem), upper ball joints, drivers side outer tierod
also just had a 4 wheel alignment done
brakes-
brembo blank rotors (brand new)
calipers (just bought reman’d)
goodridge stainless steel brake lines (brand new)
wagner ceramic pads (brand new)
also just replaced the master cylinder.
wheels-
oem gsr swirlies
kumho ecsta xs tires 205/50/15 (500 miles and AWESOME TIRES!!)
red “anodized” ball seat lugs (right style lugs for the wheels)
exterior/interior-
JDM 1 peice headlights
JDM amber bumper lights
rear wiper plug
antenna plug
dcsports short shifter w/ 94+ GSR shift knob
extras-
jdm b16 s1 cable transmission
usdm b18a a1 cable transmission (w/starter)
1991 ls hatch w/ spoiler (light green)
brand new OEM unopened hatch struts
brand new OEM inner tierods, outer tie rods, oem brake master cylinder
brand new OEM unopened rear main seal, oil pan gasket, intake manifold gasket, valve guide seals, most of the rest of the top end gaskets.
3 extra tokico illuminas and lowering springs
bunch of the old suspension, brake pieces
stock headlight and bumper lights
2 used master cylinders
3 inch high flow catalytic converter
bored throttle body (no tps)
4 axles for cores
slim radiator fan
pr4 ecu
wideband o2 sensor
misc tubes, couplers, pipes, clamps good for turbo builds
