How much does fully built motor run about?? My brothers friend has a 13sec all motor lsvtec for sale. Hes askng 3g. Just wanna know if thats about right or no?
Depends on how many miles and how well the frank was built. If its fully built for an all motor set up he spent more than 3 gs to get there. He probably spent close to 3g’s just to get the head on an LS block and wired up to run with a few mods. Depends if he did the work himself tho too. If it was my motor and was fully built (resleeved, PnP, custom cams, high compression, back cut valves, ITB’s or ported intake, micro polished and balanced crank, etc) nothing was wrong with it i would be asking a bit more than 3 g’s. Be real careful about buying a used LSVtec thats been raced unless you really know what that engine has gone though and who built it. If it was my money I would spend it on a 18c/16a2/or16b or if you really wanna go with the frank a b20/Vtec that you build yourself. I considered the LS frank option for 2 years and there is alot of controvercy over its reliabilty and longevity. Unless you have the money to rebuild I would’nt risk it.
The motor has been running for a few years without problem and not really sure about who built it and what has been done to it. The motor has seen mid 13s consistenly without problem too.
Are you gonna swap in your current car now if you buy it? What engine are you running now? If you already have an LS block I would do some pricing on heads and talk to a mech that you trust. 13’s is pretty good for all motor. You can’t always judge an engine though on how well a car does on the track. weight, tires, gear ratios, clutch and reaction time all filters into that 13 seconds. I’m not saying the engine’s bad, just realise the risks involved in buying a frank motor. Are you concerned with smog? If you live in Cali like I do you might hive some issues with getting it to pass. You’ll most likely have to BAR it. Personally I would buy an LS block/B20/or resleeve the LS to 2.0, find a Gsr/b16 head and piece by piece do or have the proper work done to build the engine yourself. You’ll spend more than 3g’s but you’ll learn alot, you’ll know EXACTLY what you have,and you might save alot more in the long run with a fresh motor rather than one that might crap out on you. If you do buy it tho, have some one REALLY check that baby, leak down, compression, inspect it through and through.
… Why are you even thinking about buying a motor that you don’t know what has been done to it? Seems to me like that is one of the FIRST things to know, regardless of how fast it runs in the 1/4mile.
http://www.phatwhippincrx.20m.com/custom4.html
Read this link bro. Although I’m not exactly against the build, i think only those who have the money for issues that may or may not arise should take this route. Me, im poor as shit ![]()
What the fuck does fully built mean? “built” is tossed around just like the word stock now a days.
my build cost almost 5k with all the parts and labor/machine work involved but that was doing everything by the book
3 k for an engine with a few years of abuse sounds kinda high
