When i bought this teg most stuff didn’t work, but thanks to you all i fixed alot of it. Here’s a problem I’m having When i hit the A/c button, the compressor isn’t turning on. The book says to check a/c relay. WHERE IS IT? It’s winter time and i want to fix it, before summer comes and prices rise with the heat. SO if any Guru, mechanic or anyone can help me with the problem please do. The A/c belt is on the compressor, it’s just not getting power i guess, so please help me. ![]()
theres two relays, one on each side of the radiator, it is covered by a rubber boot but it is square, connected to the chassis by a 10mm bolt, take those out and buy new ones and replace them see if they work now, let me know what happens
How many are there?? All i seen was one. Next payday i will replace it.
before you spend money on a relay. Have you checked to make sure there is Freon in the system.
If the freon has leaked out, the compressor will not turn on. That is waaay more common than a bad relay.
You might also want to check the A/C switch itself. Those things wear out after a while. It’s about $30 for a new one.
Cool, Yeah I was reading that haynes Guide and I was looking at the A/c System wiring and i seen the Freon level switch. I think mine is empty because the last owner went all out full drag with this car. Man I love this car. Thanks.
