I noticed as I rolled to a stop at the light…she wobbles side to side. I know I need new axles but it feels like it’s coming from the back. Could it be something wrong with the tires? Help is always appreciated.
Tell your avatar to sit straight up. Maybe that will help.![]()
dave… have you plugged any of your tires in the past and have’nt gotten new ones? check your tires over thoroughly and see if there are any bubbles. sometimes that happens if theres a break or damage to the radial. air will start pushing its way through the damaged part and will form a bubble in the tire. it’ll have a “blister-like” appearance. you may want to remove your rims to check the insides of the tires too. the only other thing i can think of is maybe you bent a rim. i dunno… if theres no bubble, get it checked out!!!
but I thought you liked my avatar just the way it is…
Steve- I’ll take a look, most likely its that bubble, cause I haven’t hit anything to bend the rim like that.
The only other thing that it can be besides a bent rim or a bad tire is u need to get the rims and tires ballanced i do this once a months keeps my ride smothe even on 18s or 17’s.
look at romeoy’s lovely boobies:D
:horny: :shock:, love your avitar.
-Andy
Tighten the lug nuts.
Check the ball joints.
Make sure the tie rods are straight.
You know, I really only saw “nuts,” “ball” and “rods” on your last post.
Ben
I have the same problem. It feels really unsafe. The guy at sears said it was the TIE RODS. This is probably your problem
JAY
once a month! you must drive more off road than on
