My transmission needs help
I have a 92 integra, RS.
The original tranny went bad so i got another rebuild tranny.
So i have S1 tranny which is a b16 tranny.
If i would change gears after 3k the gears would grind. ( in any gear)
Than i changed the fluid, than it ran fine, now when i red line it, it grinds, i can shift at 6500 without a problem, but if i redline it, it grinds like hell, than my tires chrip (he he), than the car pulls like crazy.
I been messessing around with my tranny to fix this problem, so i decided to take the fluid out a little, guess what, the color of the fluid is freaking brown. i mean dirt brown. it smells like oil but the color is like lite green, like dirt color, but its not dirt, and the oil is clean.
I’m thinking about changing the tranny fluid again.
Any suggestions guys.
Thanks
wut kinda MTF are u running??
if ur running REDLINE MTF, then i think u might wanna switch to something else…there is a problem with REDLINE MTF and Honda trannys
i heard Honda MTF is the best…
I’m using the recommended 10w30 motor oil.
change it out for honda MTF. it costs a little more (like 5 bucks a quart at the dealer) but it’s worth it. it’s what they use when they work on your car, it’s what the car comes with outta the factory. might as well use what honda uses…since honda makes the car and all. i dunno, my $.02 worth. HTH
zoom
