Need cheap fuel management, maplimiter?
My website contains schematics for how to build a fuel management circuit so you can run 450cc injectors with your tc/sc honda. Also has schematics for an electronic maplimiter for those of you running an FMU and are tired of CELs.
The FMU circuit works on the same principle as the AFC hack or the SMC but with less adjustability (2 points of adjustability, hey waddaya want for $20)
I sell either one for $20.00 shipped ($21.00 if you use Paypal) for those of you not inclined to diy.
http://www.angelfire.com/ab7/diymaplimiter
How whould one go about ordering one of these for the injectors? Will it work with all year integra? Any other parts required for instalation? How hard is it to install one of these?
There are three wires going to the MAP sensor on any Honda. One is +5 volts, one is ground, and one is the MAP sensor signal to the ECU. Hooking it up is as follows:
Tap the +5 volt wire to the MAP sensor, tap the ground wire to the MAP sensor, cut the signal wire and hook one end of the cut wire (the sensor end) up to the orange wire and the other end (that goes to the ECU) to the yellow wire. That’s it. Works for all Hondas.
Oh yeah, no other parts required, unless of course you use the circuit to run 450cc injectors in which case you need the injectors.
You can e-mail questions and Paypal to Chris_Hart11@yahoo.com
I can also give you a physical address if you want to do M.O.
I got my homemade afc from him, great dude :up:
is this still a viable solution or is it best to go with the smc?
