Need Help! Outer tie rod is rubbing the inside of my wheels
Hey guys, I have a problem I need help with. I have a 1991 GS with stock suspension riding on oem GSR blades, tire size is 205/50/15. I have been having this grinding issue when the wheel is turned more than 80%. It’s been leaving a nice little lip on the inside of my front wheels. I jacked it up, turned the wheel all the way to one side, and found that my outer tie rod is rubbing the inside of the wheel. It’s done this with 4 different sets of wheels, 2 of those sets being oem (steelies and blades).
I don’t understand why it would do this with a stock car on oem wheels. Can anyone please offer any insight or help?
Underneath passenger side wheel, looking up
Passenger side wheel again, top view
Driver side, to give you an idea of the curvature of the tie rods. With the wheel turned right, driver side does not rub.
Driver side again, to show the clearance with the steering wheel turned right. If I turn the steering to the left, the problem duplicates itself to the driver wheel, passenger wheel would be clear. You can also see the wear on the tie rod where it’s contacting the wheel.
Also, p/s tie rod has “L” on it and d/s has “R”. It’s obvious what those mean, but does “L” mean left if you’re looking at the car from the front, or sitting in the car facing the opposite direction.
I’m thinking they may be installed on the wrong sides.
wrong sides yup lol. the L and R is if your in the driver seat. did you just get them done? i would have them fix it and put new ones in.
I bought the car like this. Previous owner must have snicklefritzed them. That’s relieving though, thanks for the help!
Nice easy fix I’m curious what the hell does snicklefritzed mean haha
Snicklefritzed… ya know… it’s just like snickerdickle :slight_smile:
haha whoever installed those tie rods failed miserably. yeah they’re on backwards like mentioned above.
You WILL need an aligment after you fix them.
