Okay, here’s the deal: I’m PISSED OFF!!
This morning, everything was running 100% fine and dandy…
Parked the car for a few hours, and went to start it. It hesitated and cranked a few times more than usual.
Drove out fo the garage, and noticed a SEVERE lack of engine power. Also felt a pulsing/vibrating in the shift knob that never used to be there. When idling at a stoplight, the RPM’s would sometimes dip to 200 or so…
Anyhow, I drove for about 1 mile like this, then went to check the engine. I pulled the spark plug wires one-by-one, and on the 2nd one (2nd closest to distributor cap), I think I pulled too hard, and it broke. I replaced the spark plug wires with a brand new set.
Now, the car STILL does the hesitate/stutter thing, so it wasn’t the plug wires. The local Honda dealership said (without looking at the car) that it could be the timing belt slipped. Sounds like a possibility. ![]()
Anyhow, these are the things that are relatively new or old on my car (1991 GS):
fuel filter: new last fall
oil and air filter: 1 month old
spark plug wires: brand spankin’ new
spark plugs: platinum, 8 months old
distributor cap: dont know, never changed it in 2 years
timing belt: most likely at least 5 years old, maybe more
The last kind of gas I got was the kind I always get – Petro-Canada, good quality stuff, most likely not watery.
The car was running PERFECTLY fine this morning, and between then and the next time I started it up, something went kaputz and is causing me HUGE problems. I’m afraid to drive the car as its likely going to hurt it (especially if its a timing belt problem!).
Canadian Tire said they could do a scope test and a tune-up for me, which “should” find the problem… but thats gonna cost $130 for the both of them.
I was thinking of maybe trying to talk them into letting me TRY a new distributor cap, and if it works, great, if not, I give it back to them.
What the hell should I do? I NEEEEEED my car for work and school, so being w/o it is going to cause HUGE problems.
ANY HELP IS GREATLY APPRECIATED!!!
~Eric
