New from Hoquiam WA
[QUOTE=teg cruzr;2304940]Hi there Shane.:wave: My name is Shane. I live WA. I also have a black teg. Keep up the good work.
Here’s mine.
What did you do with your GSR blades? The new wheels look nice.
Shit… Bryan you know I still got the blades. Sorry OP. Not trying to thread jack.
Me neither. We all need to get together for another meet.
even though my teggys kinda beat up, Id be down for a meet!
We all need to get together again. It’s been too long.
Yes I did. That was about 2 months ago.
Thanks Shane! lol Your DA is sexy af, lovin’ the wheels.
No worries man lol
Gettin together for a meet would be badass. There is only one other guy down here that has a DA and thats chaggy lol
So had a bit of an issue…Thought it was the throwout bearing but upon inspection, it is intact. So I replaced the pressure plate thinkin mine was a tad old and worn, causing my clutch to not engage. After installing the trans I found the same issue, clutch pedal goes to the floor and stays there and the clutch arm on the trans goes up and stays there. So pulled the trans again and it seems the throwout bearing isnt engaging fully as it should. So I am going to replace the spring that hold the bearing today and see if maybe that is the issue.
Ahem dude why didn’t you tell me you made a g2ic account?!?!? Dick! Stacy and Betty need some karate time in the garage though!
Well if you havent noticed, Betty has been in the garage under karate time for the last 3 days! I could use some of your hard learned knowledge possibly…DICK!
you have my number and im only 3 blocks away if ya need a a hand. id be more than happy to come over and sit in the corner drinking beer:rockon:
[QUOTE=shane2133;2305342]So had a bit of an issue…Thought it was the throwout bearing but upon inspection, it is intact. So I replaced the pressure plate thinkin mine was a tad old and worn, causing my clutch to not engage. After installing the trans I found the same issue, clutch pedal goes to the floor and stays there and the clutch arm on the trans goes up and stays there. So pulled the trans again and it seems the throwout bearing isnt engaging fully as it should. So I am going to replace the spring that hold the bearing today and see if maybe that is the issue.
Have you considered the clutch cable is stretched out?? Welcome BTW looks like a solid teggy :up:
he might have a point there! oreillys has em for 40 bucks!
Thanks for the suggestions guys but found the issue and fixed it! Bad throw out bearing and bent return spring. Replaced both and got her back on the road :-). Now I have to replace the inner tie rod on the passenger side and she should be near perfect. I still have to install my new throttle body and front camber kit.
