i bought a 90 rs hatch 5 speed for $850 last week and i love it, it has 173,xxx miles on it and runs strong but it needs a little bit of work. i need to replace upper and lower ball joints on the driverside, both axles, both inner tie rods, shifter bushings, exhaust, misc. suspension parts/bushings, fix my drivers side auto seat belt, fix my oil leak, do some body work to get rid of the rust and a bunch of other stuff that i can;t think of right now. so far i’ve replace the shitty headunit with my sony one, put a new shift knob on and out some 15s on to replace my messed up steelies.
welcome to the world of the DA and DB and welcome to G2ic.com its going to be a fun adventure.:rockon:
Welcome! Here’s a few small bits of advice that I wish someone would have told me when I bought my first DA lol
Find a local wrecker, and use craigslist and g2ic buy and sell forums to save on whatever parts you can, wherever you can. If you want it, chances are someone here has it in their garage.
For balljoints and bushings use OEM honda whenever and wherever you can afford it…Most times they cost more, sometimes they dont. (For example Swaybar frame bushings are cheap from honda, endlinks are not. So I bought the honda frame bushings and the ES endlinks…HUGE difference in handling for less than 30 bucks!)
Buy your axles new, not used unless you feel like changing them many…Many times and pissing away your time and money.
As for shifter bushings, you may wanna search G2IC first and make sure you replace all the right parts. From what I have read the bushings are not always the only things responsible for sloppyness.
Seat belts are under lifetime warranty from honda. Some people have trouble finding a stealership that isnt run by douchebags and will honor it, but its a free repair though so its worth the trouble imo.
Oil leaks are normally cam seals, valve cover gasket and channel seals. Buy felpro or honda gaskets and honda cam seal plug and you shouldnt see those leaks again.
Hope that helps man, nice teg ya got there…Have fun!
Oh and dont forget to read through the Teg Tips section of G2IC…Basically everything you can think of doing, or want to do is in there!
