No lap belt? can it be easily replaced???
I noticed I don’t have a lap belt for my front driver’s side seat. this’ll be a problem whenever i go for my next inspection i’d imagine. is there a way to put a new lap belt in? i pulled the cover off the floor to see if the lap belt may have retracted farther than it should have and i don’t see it. would i be able to replace the lap belt or do i have to go aftermarket now and get a harness?? i have a couple of months till inspection, but i just wanna plan it out…HELP!
You can replace it fairly easily…
The belt is in an enclosure that bolts right into that hole you’re talking about… it’s only 2 bolts, you should check to see if they’re gone or not…
I’m sure someone’s taken theirs out after putting harnesses in…
If not, you could probably find them on ebay or at a junkyard…
I was planning on taking mine out when I get harnesses, but that’s probably not going to happen soon enough for you…
You might be able to use the pass. side belt, but I don’t know for sure.
