Nos on Stock LS???
Was wondering if putting a 50 shot on my stock LS with 105,000 miles would be okay? if not what should i do before hand?
Sure its fine, my friend also a member has a 50 shot, has been running it for about a yr with only i/h/e, i think he just went to a 75 shot, he also has over 150000 miles on the motor. One thing is for sure though one day, not next week or next month , or next year you will break/blow something Nos is very detremental to an engine.
well any tpye of FI is gonna wear on a motor. but if u do it correct and jus keep an eye on all the vitals ur motor will last a lot longer then if u jus throw sumthin on there and cross ur fingers. and u will be fine runnin a 50. hook it up get a wideband to keep an eye on the A/F and then dyno tune and have fun.
You’ll be fine with a 50 shot. I had a 75 shot on my integra for years. Just be sure not to advance your timming too much, use the highest octane fuel, only use NOS brand octane boosters if any at all, keep checking your plugs since NOS loves to burn up plugs, and only hit the NOS when your at full throttle. Doo all these things and you’ll be ok. I had a MSD ignition just to make sure my spark was big enough. Good luck man.
First of all I have to do it…its NOT NAWZZZ!!! Its NITROUS.
Second, things to check/do
-Dont advance timing
-Use high octane fuel, and use whatever brand octane boosters, NAWZ brand wont be any better/worse
-Look into getting colder plugs
-do a compression test
-search!!
You might want to do some research on octane boosters. Some boosters have a chemical that dosn’t mix well with NITROUS.
Hmmm… Ok maybe I didnt think before I said that, I just thought it strange him recomending octane boosters only buy NOS. :blah:
