OBD-1 Wiring harness...
I found someone with a B16a Grey plug OBD-1 Wiring harness. Will this allow me to put a VTEC engine in and still use my Injectors and distributor from my LS engine?? What about the IM what should i use in this case or does it matter???
its sort of a waste of money.
read the teg tips engine swap guide, its got all the info you need on swapping in engines.
93… it’s OBD-1…
I can’t find a good picture of it in the helms… for some reason i need to picture it… from end to end…
i’m trying to figure out if it would be easier to run VTEC wires along with current Wiring harness or to buy the full OEM OBD-1 Vtec harness…
anyone done either or both??
Bump…
if you get just the motor harness for the obd1 vtec you will still have to run wires to the ecu, just cause you get a vtec harness doesnt mean it goes into your harness, also i hear it wont even plug into the car harness on your ls, unless you buy the whole thing and then its a complete waste so just run the wires.
i have asked this a few times and jetspd777 or something says nope wont work
later
