obd0 to obd1 jumper harness & ecu, do I still need a obd1 distributor?
Ok to Im ready to move my jdm 98 spec itr engine out of a obd0 b16a ignition and chipped pw0 ecu for a S200 setup.
My old obd0 engine harness had all the sensor plugs cut off for the obd2 sensors on the engine, the distributor plugs stayed the same so I could use a obd0 jdm b16 distributor.
just last week I took the car out and after a spirited drive I managed to snap the head off the bolt that hold the distributor rotor, rotor stopped spinning and the car died. I had to rebuild the entire distributor since the bolt stayed in the shaft and I couldnt bolt on another rotor.
Do I have to use a obd1 distributor to work with the obd1 ecu and s200 or can I just use a jumper for the ecu plugs and call it a day…
(lesson learned to change that bolt when replacing the cap & rotor, i mean its included in the bag with the rotor)
You need an OBD-1 or OBD-2 §§§§§. I just did the same thing to my car as I’m now running a Hondata S100.
dont say obd2 man, my engine came with the obd2 diss and i let it go at the shop my swap was done…never went back to pick up spare parts left…
ok so i just need either diss and depin the plugs and repin to my harness right…
If you want to use your obd-0 plugs you’ll need to modify the OBD-1 OBD-2 pins a bit. When you compare them to the OBD-0 pin you’ll know what I mean. Once you do that it will be plug and play and you will not need any of those expensive conversion plugs.
Let me know if you need any more help.
