Oil Light
New to this site/board…
My oil light gradually comes on (not all the way - but about 75%)., about 3-5 minutes after starting the car. It fades to about 10% after a while, buts gets brighter when I hit the gas. After 20 min, it shuts off completely. Checked the oil, it’s a little dirty, but seems to be at the right level…any suggestions?
That oil light only comes on as a result of low oil pressure. It is not directly an oil level indicator. If your level is fine, then the engine should be checked by a mechanic (or yourself if you know what you’re doing :slight_smile: )
