On cdm high-rise arm rest black cloth
Comes with all necessary mounting hardware
Cup holders are perfect
225 plus shipping
Email is
Frankteg@live.com
how much shipped to 18960, very interested. why do you want to sell it?
Email me
email sent.
Does this only works with CDm belts?
Not sure
Being from Canada I don’t come across auto belt
I’m sure if it fit they wouldn’t have needed to make the usdm armrest
It will only work with CDM/JDM models unless you use aftermarket seats and seatbelt system or do a manual seatbelt conversion. It will not work with the auto seatbelts. That is why Acura produced 2 versions of armrest for the DA/DB2. The USDM (more common) is the armrest that has 2 legs that is mounted on each side of the area where the E-bracke is and the CDM/JDM (less common) is the high rise armrest which has a 2 part mounting bracket (1 “U” bracket bolted to 2 “L” or leg brackets) underneath/inside and is mounted with the rear of the inner seat brackets. The rear inner seat brackets mounting points differ from that of the USDM mounting points. The CDM/JDM mounting points are vertical and the USDM mounting points are horizontal. To solve that issue I would recommend custom leg brackets to mount. That is my plan when/if I can get my hands on a manual seatbelt conversion for a decent price.
OP, nice item with the intact cup holders. Does it have the mounting brackets too?
Yes it has the mounting bracket
quick question can u exchange the lids of a udsm one into that cdm cause i have a extra one in leather just curious might be interested thx
They look the same
I can measure it for you
[QUOTE=Frankteg;2240412]They look the same
I can measure it for you[/QUOTE]
i guess if you can i will research also on other forums
You can swap lids i did on mine when I had it recovered
Up
