on startup..car sounds weak...?
Well I use this car everyday and I know the sounds it makes and know when it makes a new sound…Well lately when i start the car up…its sounds weak starting up…but runs fine and smoothly. Could this be a problem? starter possibltity?
If it starts off sluggishly, then I would check the battery (or have it checked at the local shop), then I would also swap out the spark plugs… those are my first two to check, after that, it could be a WHOLE list of things that could be causing that: starter, coil, distributor, fuel pump, etc… you could go off in a hundred different directions, but you have to do it logically…
