So your H4 harness fit the H4H bulbs? Which harness is this and where’d you get it from?
regarding h4 harnesses
what happen with mine were I went to go get my headlights on and I was told that I would have to get new plugs. so I went to my local import car store and told them my situation and they said I need the H4 harnesses because I had H4 bulbs whereas in my stock headlights I had the 9004’s. so I picked up the H4 harnesses and they worked just fine. So try that first or have someone look at your harnesses (just in case you already have them) and then if that doesn’t work you might want to look into the bulbs and so forth.
Little update: My one pieces mysteriously came back on this evening and stayed on perfectly. High beams even worked fine. Needless to say, I won’t be getting new H4Hs…:roll:
hey guys so i got this same problem when im driving at night my low beams are so dim i cant see where im going i have to put my high beams on. And they are wired right i used a teg tip on here and i tried several diferent bulbs
7 years, really?
i think we have a winner
what?
Hey guy my light bulbs just when out on my 1pc headlight and i dont know were i can get the replacements. Can any body let me know where i can get them or witch ones should i get? thanx any help would be greatly appreciated.
Buy H4H headlight bulbs. Google is your friend.
Instead of thread jacking, you could have searched and found your answer instead.
I didn’t want to start a new one and since they were already talking about replacing the bulbs i figured they would be able to help me. I did search and that’s how i ended up on this tread. Sorry didn’t mean to jack his thread…
Thank you so much…
