One piece headlight bulbs
ok question about the 1 piece headlights…
the ones i picked up… there more of a GREENISH type instead of yellow… anyone know y? could the bulb just be old? and what kind size r the headlights. AAAANNNNDDDD how do u get to them?
bulbs are h4h, www.jdmland.com or www.passwordjdm.com sells them
You likely need to polish your head lights. Check out the Teg Tips.
H4H bulbs, Password JDM sells them.
all the bulbs r h4h… im talkin about the fogs… the fogs look green instead of yellow… the fog lights bulbs r h4h?
does anyone have pictures on replacing there foglight H3 bulbs? that i can get an idea of… cause my foglight colors r pissin me off lmfao!
Do you want to make them yellow? Or leave em white? or what?
They should be yellow. JDM head lights have a yellow lens in the fogs to give them that yellow look. H3 is the bulb you want.
I got my dash back together sort of, need to plumb the senders still but that’s minor.
[QUOTE=G2 Racer;1950561]They should be yellow. JDM head lights have a yellow lens in the fogs to give them that yellow look. H3 is the bulb you want.
I got my dash back together sort of, need to plumb the senders still but that’s minor.[/QUOTE]
so if i take out the bulb. id have to take out the yellow lens? how do i check. is there a write up on taking the h3 bulb out?
its not hard to remove the h3 bulb…just go and take a look.
Why do you want to take the lens out? You need to completely disassemble the light for that.
Just get some regular bulbs and put them in. None of that super white shit.
Also are the lights clean or do they need a polishing?
Hey sorry to revive a 2 month dead thread… But I just bought a set of 1 pieces and the fogs were a real dull yellow aswell. I pulled the h3 bulb out, peaked inside and the Yellow glass covers were nasty…
Also just to let everyone know You do not have to take your lights apart to remove the yellow covers. With a flat head screw driver you can Get the Bulb holder out and then with some wiggling you can manuver the Yellow cover and Bulb holder out of the service hole on top of the headlight housing… Just did this 2 days ago, changed the yellow covers and they are good as new.
Mk1shitrocket: Do you by any chance have a pic of the fog light area. I just got some one piece headlights and tried putting the bulbs in but the area seems to be too big. Just wanted to see if there is a piece missing.
Thanks
^ x2 pics would be helpfull
actually yeah I have to do the other side so I will try to get some pictures tonight…
