I am having a brushing noise in the front of my car, it happens when I am driving straight, and stops when i play with my steering wheel back and forth, and apply brakes.
The last time I changed my brake pads one wheel was worn all the way down while the other was untouched, and i believe on the wheel itself, only one pad was worn, the outer one i believe.
This noise makes me think of this happening because maybe it can help. This noise is embarassing.
exactly what he said if the caliper is seized or the bolts it slides on are stuck it will do that. take off the caliper and try to compress the piston and also pull out the slide bolts and clean/lube them
the sliders come out of the caliper. if they’re seized, chances are you won’t be able to get them out in reusable condition.
may have to buy the whole caliper.
to lube, pull them out of the dust boots and use the appropriate slider lube, and only slider lube. when reinstalling them into the dust boots, be sure the boot seats in the groove of the slider properly, otherwise dirt will get in and dry them up. which causes them to seize.
even when buying new, as a precaution, i like to relube the sliders with my own lube
but, without detaching the line, try and free up the slider in your caliper that’s in there now. it may not be completely seized. if you can, clean and lube up those pins and fire it back together. make sure the boots don’t have any holes in them and that they go back over the sliders properly
If you can get the sliders out and they have rust buildup on them, take some 80 grit sandpaper and clean them to bare metal then apply a silicone based lubricant on them.
[QUOTE=welfare;2135063]the sliders come out of the caliper. if they’re seized, chances are you won’t be able to get them out in reusable condition.
even when buying new, as a precaution, i like to relube the sliders with my own lube[/QUOTE]
I’d never heard of slider-specific silicone-based lube until reading this thread. I used plain old wheel bearing grease on my caliper sliders last time I replaced my brake pads. Is this going to cause problems?
the pins should slide in and out of the carrier easily. if you get them out, clean them up with some emery cloth. if they don’t slide in and out smoothly after cleaning and lubing, get another caliper/carrier. i don’t think they sell the pins or carrier separately, but i could be wrong
