Overheating/coolant shoots out of radiator
I’d go OEM, but I am not sure where you find 1-layer head gaskets…i guess I havent been looking hard enough or something…
so no cometic?
No question, OEM.
cracked block or bad headgasket…use oem head gasket dont be cheap …trust
i have redone the head and the gasket and also changed the water pump,cleaned up the radiator and changed the hose pipes and the gap between radiator and fan is perfect but still my car shoots up the water within the normall temperature???:hyper:
It still blows the antifreeze everywhere whenever you start it with the cap off?
shoots out the water
when i start the car there are no symptoms of shooting the water,but after it runs for few kms it starts boiling and shooting water out
Replace the radiator, I will bet anything a good portion of the fins are smashed flat. I had overheating issues for sooooo long and did everything but the radiator (I also knew it wasn’t my head gasket tho)
I never thought my radiator looked that bad, but lo and behold, replaced the rad and everything was copasetic.
Smashed fins play a huge part in the radiator being able to do it’s job. If it can’t breathe, then that could cause everything to heat up quicker than it should and start shooting out. I seem to remember mine shooting out way faster than it should have when I had this problem going on.
