Please Help: removing lower PCV Hose
Little backstory:
Alright so I have a 91 GS M/T and I’ve been having what I thought was an exhaust leak all this time but I could never figure out where it was coming from. Anyways I went and got my car smogged today and it passed emissions just fine. I waited forever to get it tested due to a notorious bouncing idle problem that I finally fixed after replacing the TB gasket and tweaked with the FITV. I figured I wouldnt even waste my time trying to get it smogged while it was still bouncing. Which was a good idea
Upon visual inspection the smog dude noticed the lower PCV hose was disconnected from the grommet in the manifold, Thus failing me (DOH). So I lifted the car and pulled the hose off and found it had cracked about an inch below the grommet. What im gonna do to pass the test is just put a tube over the broken part sticking out under the manifold, (it acts as a nipple basically) and then connect the other end of the home made tube to the other broken end of the OEM tube that fits into the engine block. Which works…its just ghetto as hell and it will bug me.
Thats the lower hose, mine broke at the first bend from the top near the grommet. how do i remove the grommet at the top from the manifold so that i can install a new one, and will i have to remove the manifold?
if your trying to get the old groment out i just used a screw driver and pushed on the sides and pushed down to get the old one out. happends in ny with the cold winter. hope this helps
thanks man
