please help...wheel locked
two things… first you need to know the story…i recently did the wiring for my cd player in my 91 integra rs. and when i tested to make sure it worked i moved the cd player to unplug it and it shut off. at first i thought a crimp came undone. or a blown fuse. so i took my key out and tried it again. but when i tryed to turn my key the wheel is locked. now i cannot move my wheel or turn the key at all. and yes i did try to jiggle them both at the same time. i checked all the fuses in the fuse box and under the hood. it might be a short circuit. but i dont know what to do in case of that.
does anyone know how to unlock a steering column… or why it might be locked up?
know how to diagnose if the ignition is out…
or anything else would be helpful
STOP posting this everywhere. sheesh.
http://www.g2ic.com/forums/announcement.php?f=29&a=13
OTHER POSTING NOTICES
Performing the following actions in this section may result in your posting allowances being suspended or your account removed.
  • Multiple posts of the same/similar threads in multiple forums.
