plug gap?
whats the gap for 92 integ ls?
it should say on the sticker under your hood. sorry, can’t remember exactly what the gap sizes were…but check there.
plug gap
should be .044 inch or 1.1 mm recommend using ngk plugs
you can get a manual, it’ll say in there, but better to see what the spark plug company recommends. Then get a feeler gauge and check the gap…plus with that gauge u can do valve adjustment.
I usually juss tighten my plugs, then untighten about half a turn. It’s about .5 from that, which is close to .44. Or you can get pre-gapped plugs.
If you get proper plugs for your car (NGK) then you need not worry about gapping, as they come pregapped.
The last number on the plug refers to the gap in mm.
BCPR7EVX11 for instance has a 1.1mm gap… coincidentally, thats the proper gap for most hondas’s.
-T
well, if your ignition sys. isn’t up to snuff, you might wanna close the recomended gap down a bit to around .039-.040
just a suggestion…:wink:
