Problem wiring ECU for my B16A, Please Help 😕
I have a 92 LS with a B16A. I finally recieved my ECU but I’m having a problem. I haven’t been able to find the correct chart to pin up my ecu with. I need to run the VTEC wire and the Pressure sensor wire. Please help. I’ve figure the VTEC wire from other web sites but no one seems to know what wire I need to plug in the the sensor. I don’t need to worry about the knock sensor because it has been deactivated. Thanks :bow:
what ecu are you using
here ya go!!!
you’ve got mail.
let me know if you have any more questions.:cool:
Make sure you are using an OBD1 chart! OBD0 pre-1992 will not work!
VTEC is A4
VTEC Oil Pressure is D6
Thanks everyone. I have a P28 ECU. I had found the A4 and D6 wiring set up but that only problem I had was that fact that I only have 3 ports, not 4. I went ahead and tried what would be D6 and it didn’t work. It kept throwing trouble codes for VTEC pressure switch. It turned out to be a bad pin and once that was fixed and the code cleared, all was good. Thanks again everyone. Peace.
