I bought a Rrothane engine mount insert kit over a year ago, and I finally got around to being able to use them during this motor swap. The left and right inserts went in fine with a little elbow grease, but the rear mount won’t go in at all.
On the rear mount inserts, they look to be molded to the proper “design”…but the bottom of each insert that goes IN the rear mount, are both way too big to fit in the space in that rear mount. Even a significant amount of force wouldn’t get these inserts installed, they just plain won’t fit.
Has anyone else ever had this problem with the Prothane rear inserts?
EDIT: Here’s a pic I found online, and edited, to show you which parts of the rear mount inserts are 2-3 times bigger than the spaces in the mounts…
It’s not a matter of 90-91/92-93 fitment, since both share all the same mounts/part numbers except the left mount…so I do have the right Prothane inserts.
