When I’m cruising on freeway sometimes the car will start pulling to the left gradually, and increase as I keep rolling. During the pulling I will fell some vibration in the steering wheel. I check the tires when this happen and of course the ttires are not low. If I let the car sit for a few minutes and get back on the freeway the problem completely dissappears. Until later when I’m on the freeway for a bit. I’m thinking CV joint, but I just had them replaced a year ago. I also have a 3"-4" drop. Any thoughts? Thanks in advance!
hmmmmm…
seems too obvious but have you had your car aligned, especially since you had it dropped. also make sure your drop is even at all four tires…especially if the drop is new and the springs have settled more. just my .02
Have you run into any curbs/potholes lately? … That might have knocked your alignment out … the wobbling is probably your tires … head in to the alignment shop, and have them align your Teg, and balance your tires too. Should solve your problem. CVs tend to grind/click when they go, they should not cause a wobble (unless they are really toast). Check to see if your boots are split, just in case.
Yah, I’ve had the alignment done twice since drop and camber kits. No, no pothole problems either, just moved to Foster City and the roads are damn near perfect. Strange enough everything is absolutely fine today. It just happens once in awhile. <sigh> :sad:
whens the last time you balanced your tires? Have you replaced your stock shocks or did you just put coil over or lowering springs on them?
Suspension setup-
GC springs w/tokico blues
ST bars w/bushings
braces
I’ve had this setup for just 2 years and replaced CV’s jsut about a year and the boots still look good. Thanks you guys, I really appreciate the input!!!
