Quick Questions about Putting a Hydraulic B Series Transmission in G2 Integra
Okay so long story short I just bought a DA with a JDM B18C (Type R) swap and it has the JDM S80 J4D LSD transmission.
The previous owner being the genius he is decided not to buy the proper mount conversion kit and he just twisted a stock cable B series transmission mount and put 2 bolts in that he could make fit and called it a day…
So I have since bought the proper Hydraulic B Series transmission mount for our G2 teg’s. But the only thing is the transmission does not currently have the plate on it that bolts into it before you put it into the actual mount. Now I don’t know if hydraulic B series transmissions even have the same kind of plate like we do for our cable transmissions.
So I have 3 quick questions for someone knowledgeable on this subject:
  1. Do the hydraulic B series transmissions normally have the same kind of plate that has to be bolted into the transmission before actually mounting it like our cable B series transmissions have?
  2. Do I need to get one of these plates for the hydraulic B series transmission in order to properly use the Hasport mount I have bought? If it exists I imagine I do need to find one somewhere lol…
  3. If the plate exists is it the same as the one thats used on our cable B series transmissions?
Currently I just finished up mounting a b16 into my 93 DA and I’ll tell you the “mount” on top of the trans I simply removed it and placed my Hasport mount in it’s place and bolted it up.
Works fine for me, I’m not sure I did it the “right” way but in my opinion it’s running just fine and having no issues at all.
Hope this helps,
John
Yeah I ended up doing the same thing after going to the junkyard and looking at 3rd GEN Tegs and seeing how their side transmission mount bolted up.
Seems to be working just fine for me too, its very solid.
