# Radiator drain plug broken in half
**URL:** <https://forum.g2ic.com/t/radiator-drain-plug-broken-in-half/55948>\
**Category:** Stock Engine-Bay Components\
**Created:** [November 11, 2004, 1:04am UTC](https://forum.g2ic.com/t/radiator-drain-plug-broken-in-half/55948 "2004-11-11T01:04:29Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![system](https://forum.g2ic.com/user_avatar/forum.g2ic.com/system/32/1_2.png) [@system](https://forum.g2ic.com/u/system)\
**Post date:** [November 11, 2004, 1:04am UTC](https://forum.g2ic.com/t/radiator-drain-plug-broken-in-half/55948/1 "2004-11-11T01:04:29Z")
</div>
I managed to get the broken half of the radiator drain plug out. My problem is I cannot find a replacement at autozone or any other autoparts store that can match the exact threads and size. I tried that HELP! brand. There was a few Honda ones and tried to match the closest one to it but no luck. Its really frustrating. Anyone know of this part # ? Thanks
**Post date:** [November 11, 2004, 1:30am UTC](https://forum.g2ic.com/t/radiator-drain-plug-broken-in-half/55948/2 "2004-11-11T01:30:54Z")
</div>
When mines broke I went to the junkyard and located a half size civic raditor and “borrow” the drain plug. It was the same size perfect fit. But the acura dealer should have a plug since its an OEM part.
Here you go also
[http://www.autopartsworld.com/1991\_acura\_integra-1-8rs-ls-3dr\_radiator-drain-plug\_parts.html](http://www.autopartsworld.com/1991_acura_integra-1-8rs-ls-3dr_radiator-drain-plug_parts.html)
**Post date:** [November 11, 2004, 1:59am UTC](https://forum.g2ic.com/t/radiator-drain-plug-broken-in-half/55948/3 "2004-11-11T01:59:02Z")
</div>
Thanks for your help.
**Author:** ![Louie55](https://forum.g2ic.com/letter_avatar_proxy/v4/letter/l/6de8d8/32.png) [@Louie55](https://forum.g2ic.com/u/Louie55)\
**Post date:** [November 11, 2004, 3:07am UTC](https://forum.g2ic.com/t/radiator-drain-plug-broken-in-half/55948/4 "2004-11-11T03:07:24Z")
</div>
just go to home depot or something and find a bolt with the same thread pitch and size. get a washer and some of that white pipe tape (forgot what its called).
**Author:** ![eusbocr](https://forum.g2ic.com/letter_avatar_proxy/v4/letter/e/5e9695/32.png) [@eusbocr](https://forum.g2ic.com/u/eusbocr)\
**Post date:** [September 20, 2009, 3:09pm UTC](https://forum.g2ic.com/t/radiator-drain-plug-broken-in-half/55948/5 "2009-09-20T15:09:42Z")
</div>
Teg\_Fury…
How did you get the broken part of the drain plug out of your radiator. I have the same problem right now.
Thanks!
