Radiator ?
I already know the pros and cons about getting a half size radiator, and ill be getting a bmc log with a t3/t4 57 trim and im not sure it will clear my radiator, so i thought about getting a half size now cause i need a new rad any ways, do you guys think this one would be ok http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7978898621&category=33602 its all aluminium and 2.5 inches thick which is thicker then the stock radiator i believe by almost an inch
It will work fine, I have used that radiator in 2 cars without problems.
would this be ok http://www.radiatorbarn.com/s7.asp?...ngine_size=1.6L , or would i need an aluminum one? and is there any problem with radiator hoses with the use of a half size radiator?
any one know about the radiator hoses?
come on please, I bought an aluminum rad. for a civic today and I really need to know what I need for when I put it in
Will Someone Please Answer My Questions, I Spend Lots Of Time Answering Questions For Other People But My Shit Just Gets Looked Over
im not sure on the application of hoses you would need, but i do know that the oem hoses are the best, you need to test fit the rad, you might be able to use the stock hoses you have now.
anyone else, i got the rad. in today so im gonna try fooling with it this weekend
just cut off the old mounting tabs on rad support and relocate it wont hit oem crossmember
well it has the mounting posts for the tabs but it also has posts with threads for a bolt, I was gonna use those and fab up some brackets, I was more worried about the radiator hoses placement and size, it looks as though everything will fit fine though
