I’ve searched but like everyone else on here that has searched, all that we can come up with was that “it’s a pain in the ass” but not a how to do it post. so if someone out there would like to be the first, please do…cause i need to know!!! my rear mount is screwd!!! tia!!
I’ve never done just the rear mount, but this is probably how I’d approach it:
Support motor
Remove front mount and tranny mount
remove bolt from rear mount
twist motor and remove the rear mount bracket
replace rear mount and reassemble in reverse of disassembly
tighten mounts in order listed in service manual
HTH
Dont forget to move ur starter possibly ur half shaft just for ease of access.
i didnt use innovative mounts but i can give you some tips on the back one. this one is a bitch, you should have: 2 people (this is a must), universal joint, buch of extensions for your sockets, a jack, a prybar of some kind, and just basic handtools. heres what i did:
(start by removing things that will get in your way such as intake and fuel filter, i also had to remove 2 coolant hoses going into the firewall)
- start my taking off that x-member that goes parallel with the car, theres 3 bolts in the front and 2 in the back.
- unbolt the bracket thats connected to the underside of the intake manifold, i did not get this piece comepletely out but it did help to have it loose.
- unbolt the bracket holding the engine mount in. make sure there is a jack on the underside of the engine for this part. if i remember there are two bolts down low that you access from the bottom then there is another one up top that you get from the passenger side.
- unbolt the mount from the bracket from the pass side.
- unbolt the mount from the car. there is 1 bolt on the front side of the mount, do this by making a big chain of entensions. then there is 2 on the backside, use a bunch of exensions and a universal joint and have a person down low put the socket on the bolt while you turn it.
6 that should about do it for removal, your going to need to do some prying to get everything out of there, also unbolting the side mounts probably wouldnt hurt.
[SIZE=“3”]THANKS TO THE GREENONE3589[/SIZE]
