Hey guys. I got an obd0 b16a in my teg. One of the coil packs are cracked and is the suspected reason causing a miss fire to happen when the car is running at a steady cruising rpm below 4000. I believe it still misses after that until vtec engages but the engine is spinning fast enough that it is only slightly noticeable. I’m wondering If there is a distributor i can use in place of it(I remember being told the distributor off a b18a will work but doesn’t bolt on correctly) or if i can use the guts from another usdm distributor to rebuild mine. $200 some dollars to buy one doesn’t sound like my cup of tea… I don’t even think they come rebuilt… so sad
u can use an ls distributor but u gotta cut off one of the legs so u can mount it up… not the best way but has been done b4. why not just look around for a good used one?
because a good used one from where i live will have to be ordered and it seems that that price starts at $200. That’s why i was curious if the guts out of another distributor would be interchangeable so i can just rebuild my casing that i have right now and then not have to worry about it having any problems. catch my drift?
http://g2ic.com/forums/showthread.php?t=164955
Yes It can be done, this was odb1, but im sure you could find a suitable donor and make it work
i’m sure it can be done but that is exactly the problem i don’t have money to be blowing on distributors to find out which one’s guts are interchangeable. I was wondering if someone already knew which distributor parts i could use. Anyone?
