hey guys i need help…
how do u remove that blasting thing…the intake resonator without taking off the BUMPER???
pls give me all the tips…all the tips…THANK YOU ALL!!!
btw…i dont want to remove my bumper bcoz its a kit…fiberglass kit
Just pull back the bottom part of the inner fender liner and you’ll see the resonator. There will be 2 10mm bolts on the side facing the rear of the car and 1 10mm bolt on the front. The rear 2 should be easy, but to get the front one a ratcheting wrench would be immensely helpful.
It really takes about 10-15 minutes to remove the bumper… it will make removing the resonator a hell of a lot easier.
-Thomas
Yea, remove the bumper. I took mine off without removing it and IT SUCKED. Getting to the last screw is the hardest thing in the world.
Intake Resonator
Yeah, definately just take off the bumper… It only takes a couple of minutes, and it makes the work SO much easier. It does help to have an extra person when you put the bumper back on though… ![]()
i just took the inner fender out, and then got underneath the front w/ a pair of tin snips and butchered the last plastic support till it came out, then took the bolt out.
I gave up on taking it out so I did the next best thing and removed the bottom half of the airbox. The intake makes a bad ass sound now when I open up the throttle. ![]()
thanks guys:cool:
