Will anyone explain what is involved with removing the head. How do you take off the distributer? What about TDC? Thanx
STEP 1: BUY A MANUAL.
otherwise you will be totally clueless as to what to do.
You can take your dist. off by taking off the three bolts that are attached to the head.
If your going to do the head removal which is quite easy with proper organization, make sure to keep all bolts together. Mark all your bolts for identification for when you put everything back together. Use platic baggies for storing bolts from a certain section of the head or part.
