how hard is to do this? how long should it takes??
I know all the haynes manual says to remove the driver side axle, but can the alternator be removed without removing the axle?? I know this is possible, but what is the exact procedure??
rumor has it that if you remove the oil filter (and don’t care about your knuckles) you can spin it around a certain way where it will just fit through.
Either way… Not Fun!
Thank god I’ve never had to change mine…(I hope I didn’t jinx it by saying that)
One day I was driving down the road and the Telltale light came on. My heart sank. I pulled off the road and looked into the engine to find the Belt had snapped off. I started cheering and jumping up and down on the side of the road, “Yipeee!!! It’s only the belt!!!”
yeah, I though it could be my alternator, but it turn out my battery is going bye bye… I checked the voltage with the car stopped and it was 12,42V… which is a little low! i’ll start by the battery, it’s cheaper and a lot easier to do!!!
