How do i get the air pressure meter to work?
setting 0 and 0
I did this and it killed my car. I have it at 1, 1,
If i choose the “flap” sensor it will work… but then it will throw a code.
i will go check it again,
it’s at 0 0 pressure type. check your sensor readings if u are getting a constant value then u should look into the wirings. it usually says my manifold is around 400-500 at idle.
What does the NEpoint mean?
your safc can display form like 1000 - 8000 ( i think) ont he graph it shows in by 500’s. NE points are basically the 7-8 spots that u can adjust fuel. for example if u have a v-tec car u might want to put one ne point for 4000 and one for 4700 and one for 5000. basicailly this 'll allow u to set it before v-tec during changeover and afterwards. however this takes 3 spots and i think u only get like 7-8
