Seat Belt Warning bell and Window Regulator
I need to know how to correct or defeat the warning light and bell for the seat belts. I have a '90 LS and if I move the drivers seat all the way back, the seatbelt light and bell blink/ring continuously. Can I fix this or can I defeat it somehow. I wear my seatbelt anyway, so even defeating this is fine, just real annoying driving like my mom… also, mine has manual roll up windows and the regulator is stripped out I think. When you turn the window crank (its not the teeth in the handle I checked that) it just grinds like teeth slipping on a gear. I have called and priced the part, need to know how hard it is to swap out. Thanks.
check the little connector under your seat. there is a litle connector that sends a signal about your seat belt. check if it is connected right.
