Setting Proper Ignition Timing
Hi there fellow G2 owners. I am as of now using OBD0. I would like to make sure that my ignition timing is properly set. I have found the OBD1 ignition information but since the plugs and what not are different between the 2 different OBD statuses I’m hoping somebody on here could point me in the right direction. Thank you for any help.
I am talking about using a timing light and adjusting it with the §§§§§. I am not talking about anything to do with the cam gears or timing belt side of the engine. I am talking about IGNITION TIMING, not cam timing. Thank you.
Yes I have had people answer with cam timing advice and had no clue what I was talking about when it came to ignition timing.
mark the oem dizzzzy timing if there wasnt any changes, you losen 3 bolts on the dizzzy
than start the engine up
turn the dizzzy few degrees, you can feel and hear it retards and advances
after you done just tight the bolts , if dizzzy timing two advance you will have engine knocks , too retard the car will accl slow
you have to bridge the 2 pin plug under the dash pass side, start the engine, let warm up to proper operating temp, undo distributor bolts and adjust to spec, tighten up bolts and remove bridge wire, if you dont bridge the wire under dash the ecu will not remember the new setting!
so you saying eventho, i advance the timing on dizzzzy , it will go back to factory spec even the dizzzy is turned, is this true?
i thought you turn it it will change, pls explain some more
remember i read about this somewhere long time ago , but i didnt understand why
Ok as I said I know how to do it but what connector do I use under the dash. I have two clips under my dash that don’t go to anything and they look the same so how do I know which one is which? All the instructions I find are for OBD1 set ups so I already know what that plug looks like but not the one for OBD0
Reply to coke…
I cant remenber excally why but i think its got to do with the electronic advance, if your car a vacuum advance then it dosent matter, i read about it in a honda manual where i used to work…buts thats 2 years ago.
you will adjust it manually by turning the dizzzzzy, but the the ecu also has to know what changes you made so it can advance the timing electronically while driving.
i have two da6 xsi integras out side my house, one is mine (1992)
and one is my friends (1991) Difference between them is is the injection systems. my car has two connectors one is a 3 pin for the diagnostic plug the other is a 2 pin plug the jack cable for reading fault codes also for setting the dizzzzy, both are grey, my friends has 2 two pin plugs one is white the other is grey, its the grey one you bridge to set timing, the same plug you use to read fault codes.
hope this helps
