sir2 swap questions
ok so im doing a b16swap on my 92 integra. i already have the tranny for it. it is a cable b16 tranny with lsd. when buying a clutch what car should i buy a clutch for? i was thinking a 92-93 gsr but im not sure?
also it needs a raditor, should i just buy one for a 92-93 gsr since the b16 has smaller water nexts? and then buy new raditor hoses for a 92-93 gsr?
no one in g2ic can help me
buy the clutch for whatever year/model the trans is…i.e. 90 j1, 93 ys1, s4c, etc. etc.
[QUOTE=b18integraboy;2078413]ok so im doing a b16swap on my 92 integra. i already have the tranny for it. it is a cable b16 tranny with lsd. when buying a clutch what car should i buy a clutch for? i was thinking a 92-93 gsr but im not sure?
also it needs a raditor, should i just buy one for a 92-93 gsr since the b16 has smaller water nexts? and then buy new raditor hoses for a 92-93 gsr?[/QUOTE]
yes on your second question
If you read the swap guide, you would have your answers.
Y1, S1, A1 or J1 90-91 clutch
YS1 92-93 clutch
You can use your lower hose but will need to buy the 92-92 GSR upper hose.
The auto parts store will nore than likely not be able to supply the upper hose, so the dealer is your best bet.
well the tranny does not have the sticker on it that indacates what kind of tranny it is. all i know is that my friend had it in his EF hatch with his obd0 b16 swap. is there anyother marking that would help me figure out what trannys i have?
have the input shaft measured. the 90-91 has a different spline size than the newer. off the top of my head i cant say which is is bigger or smaller but i know someone on here could for sure tell ya
look for posts by member “scratchymaster” he got screwed over when the thought he bought a ys1 tranny. one of the differences is obvious in the casing. there is a bolt that retains one of the shafts on the tranny (probably the countershaft?) a ys1 or other obd1 tranny will have 2 of these bolts. 1 bolt means an older tranny. then you just buy the clutch accordingly. again, look through his posts. you will find a picture eventually. i think he also had a for sale thread with the info in it.
EDIT: found it because i’m awesome!
[QUOTE=scratchymaster;1988181]I just wanted to add this.
If you do not have the bolts #1 and 2, you do not have a 92-93 ys1. I just got lied to by a seller.[/QUOTE]
i do know it is a b16 tranny cause i rode in the car all the time. i did find markings that had " YSK" what ever that means
YSK is a manufactures casting mark on both the JDM and USDM tranny cases. It can be seen in the pictuer above (2 inches above the fill plug).
Since you won’t listen to what anyone has to say,Here is the best way for you to find out what clutch you need. Pull your tranny and check if the clutch disk fits on the input shaft of your new tranny. If it does order the same years clutch disk as your car, if it doesn’t order the other years clutch disk.
[QUOTE=2ndJenn;2082578]YSK is a manufactures casting mark on both the JDM and USDM tranny cases. It can be seen in the pictuer above (2 inches above the fill plug).
Since you won’t listen to what anyone has to say,Here is the best way for you to find out what clutch you need. Pull your tranny and check if the clutch disk fits on the input shaft of your new tranny. If it does order the same years clutch disk as your car, if it doesn’t order the other years clutch disk.[/QUOTE]
you’re gonna make him work, eh? you’re a meanie! :rofl:
