Skunk2 Stage 2 cams
Ok so I have a JDM GSR motor in my DA with the stock 10.6.1 compression ratio. I have all my regular bolt on’s and I’m ready for cams. I’m looking into the tuner 2 cams but I’m aware that I also need to up my compression ratio. What would you say is the sweet spot(compression ratio) for these cams? I don’t want to under cam or over cam. Also will get the cam gears, springs and retainers…
You don’t need to bump up compression to run these cams. I personaly have the same B18C in my car and I’m saving up up for Skunk 2 Stage 2’s but Pro series. The must have thing to run the cams is the proper springs and retainer and engine management. I currently running Hondata on my car and my tuner says he can get me over the 200whp mark tanks to the cams and my other mods.
Well if you go with higher compression it will compliment the cams. I got an answer on Team Integra and 11.6-11.8 is good. You’ll be hapier if you run the right compression with cams. I would search just a little before running those pros with a stock motor, expecialy pro 2’s. At stock compression your car might be faster with just itr cams because the compression ratio will compliment them better…
Well yes the higher compression will make em nicer but unfortunately opening up my motor and swamping out my pistons is not on my to do list.
I would be curious to compare our results afterwords to see how much more power the higher compression will yield.
you got to pay to play…
you cant set out a plan and then expect to get good results when you half ass it since you have low funds. To each his own…
the difference on the comp is night and day just like running all motor B18a vs B18c
swapping pistons is easy and the type r pistons can be found with rings for no more than $200 if you shop
around.
you can run itr 11:1 or ctr 12:1 or high 12 comp pistons
There’s a reason Skunk2 have recommended compression ratios for their cams.
You can always get in touch with them personally though… I’ve called S2 on numerous occasions and they always get me straightened out.
To each their own, I personaly am not going to do it as my car sees the road maybe 4 times a year. So I’ll just stick to the cams and springs and retainers and maybe in the future I’ll tear down the motor and build it but if I do that it’ll probably be a long time project to built it for boost. Then again that also will not happen until my wife finishes her masters and purchase the right house with a garage.
There’s no need to explain why you did or didnt build your motor a certain way.
But quite simply, the facts are that Skunk themself recomend higher compression ratios than stock for said cams. Will it make your motor completely unfunctional if you dont meet those specs? No… But will your performance be ideal? No, because the internal parts of the motor arent complimenting one another.
You are right on the idea of retainers/springs, as you want to match those to the camshafts being used. But to a point, the piston selection falls in that same category.
With the stage 2 cams you can get by with ITR springs because of the RPMs the springs are designed to operate are close to the cams. If you plan on going further you will need to use better springs to prevent valve float. This is the purpose for the stronger valve springs. Stiffer spring = more RPMs. However, if your bottom end is not built for the higher RPMs, you will end up with a nice B-series coffee table! For those of you who are keeping up with the thread, all of your parts need to work together. Decide what you want your build to do and build the base a little stronger! If you want to turn near 10k RPMs, get a 4140 stainless crank and forged rods. If you just want a loppie Idle ITR springs and cams all the way!
Designed/Intended RPM range isnt the end-all/be-all when deciding which springs to run…
Tuner2s have a cam-lift of 12.4mm Intake and 11.9mm Exhaust, where as the '00 ITR cams are 11:5mm and 10.5mm… using a cam that has higher lift than the springs can tolerate will result in coil-bind and/or the possibility of dropping a valve.
While you might be able to ‘get away’ with using R springs, its a much better idea to use springs that match the cams. People argue the same story with using R cams on a stock B16 head… yes it might ‘work’, but who knows for how long.
edit
And a stock non-knife-edged crank can run 10k rpm without issues of reliability… as you said, its moreso the bottom end fasteners (and possibly the installation of a girdle) that need to be worked over.
Let me clearify.
For normal, everyday driving, the ITR springs are close enough to work with the Skunk2 Tuner2 cams. If you are racing you need to upgrade to stiffer springs!
The engineers take many factors in cosideration when designing parts, but RPMs is main part of spring design. Stiffer valve springs prevent valve float at the higher end of the RPM range. Valve Float is the valve staying open longer than the cam is designed to hold it open, which leads to piston to valve contact!
I have seen people debate this, however the fact are the B16a and the JDM ITR heads are the same casting. If you were to look at them they are both stamped with a PR3. I have had they side by side and tore them down, other than the springs and valve stems, they are the same! The JDM ITRs have a larger valve stem, but just bearly!
My point was to over build you bottom end for reliability. I have had stock cranks break and I was not turning high RPMs. If you were to spend the money to have you stock crank x-rayed and magnafluxed, then chamferred, lightened and balanced, yes it can turn 10k.
It is all in your preparation of your bottom end. I have seen way to many broken cranks and boomerang shaped connecting rods working in a machine shop! I might know what I am talking about, but what do I know?
[QUOTE=zz383mero;2231547]
Let me clearify.
The engineers take many factors in cosideration when designing parts, but RPMs is main part of spring design. Stiffer valve springs prevent valve float at the higher end of the RPM range. Valve Float is the valve staying open longer than the cam is designed to hold it open, which leads to piston to valve contact![/quote]
I understand… but that does not take away from the fact that coil-bind occurs when you over compress any spring. So as i said, running a cam that is designed to open the valve further (which will compress the spring further) then you run the chances of not only Valve Float, but Coil-Bind.
You seem to be implying that I was saying ITR cams cant fit in a B16 head… That’s not what i said. We all know the B18C Type-R and B16 both share the PR3 casting, meaning the cams will interchange… hell, we all should know that B18C1 GSR cams fit a B16 head.
The point of what i said is people debate that B16 springs are fine with Type-R cams as long as you keep the stock redline… while yes, problems are more likely to happen at a higher rpm, valve float isnt the only problem.
When you excessively/over compress a spring, many many times in a row, very rapidly (high rpm) the spring will eventually give out and bind.
It is all in your preparation of your bottom end. I have seen way to many broken cranks and boomerang shaped connecting rods working in a machine shop! I might know what I am talking about, but what do I know?[/QUOTE]
Im not taking away from what you know nor your personal experience… im just saying, there’s no need to spend high dollars on an aftermarket crank. A ton of people are pushing very big numbers, reliably, with stock units. As you said, the other components in the bottom end have to be taken into consideration as well.
This will happen with stock cams as well! I have seen springs collapse due to over reving a stock engine. Also over time, they will develop weak spots which can snap!
I have been building engines for a very long time. I have seen many types of failures. I also know what will work. While I may not have a engineering degree, I have expeirance! You would be surprised what can work if you have a little bit of skill and some resources!
I also know about buget. While having an automotive machine shop in the family is very nice, I am not made of money.
Years ago, when I was building a B16a2, I scored a great deal on a set of Skunk2 Tuner2 cams. After a little bit of research I decided to order a set of ITR springs to go with the cams. It worked fine for a daily driver. If that is all that you will be using it for, it would be okay.
The B16 ran that way for two years untill the car was stollen. The thieves destroyed the engine while joy riding! When I got my car back there were extra cooling holes in the sides of the block.
Moral of the story is, you must know the limitations of your parts. If they had never taken the car, who knows, it may still be running the way I built it or it might have went out on me the next day!
All in all, am I telling him to this is what he should do, no! Am I saying ITR springs are designed to work with them, no! I am passing on knowlege gained from expeirance, so that others can make their own decision!
Also I am not trying to contradict or put down your knowledge. You sound very knowledgable, but have you ever tried what you are talking about? I have and it does work depending on the application!
P.S. The failure was not in the valve train, the B16 slung rods from over reving!
Ive thrown together a few motors and seen various failures, from various causes (none of which were anything i worked on, thankfully!)… but i dont own a machine shop nor have I assembled race-motors for customers etc… Just basic fundamental knowledge of motors and some of the theory behind them.
If Honda engineers were smart (which we know they are) they’d design said R springs so that they could take more abuse than the camshaft could dish out, so it would make sense for them to handle a slightly more aggressive cam with no issues.
Ive read through handfulls of threads, and while no instance is going to be identical to another, it makes more sense to me to upgrade the crucial elements like that which can make or break a build. That and my OCD eats at me when things arent ‘matching’ heh.
Wasnt trying to argue with ya, just stating my opinion based on the info and experience I’ve acquired. Good to have some debate and info come out of the discussion though.
Well stated Sir, and I am glad to keep the discussion civil! Most of the time people want to argue.
I must admit that I am always experimenting to find new ways of doing things and in doing so I break parts. I wish I had an engine dyno because I know it would be cool to see when parts let-go! I think of something then try it to see what will happen. As a result I spend a lot of time fixing needless damage! This is how you learn. How else will you know the limit unless you push it till it breaks. I do not suggest everone to do this! I do it because I can, and when I find something that works I can use it on other engines.
Over the years, I have done things that most people wouldn’t think of and some of it works, some don’t. It is fun when you get to see eather way!
so if you want a fast daily driver, its very important you match the cam with the right compression. if your trying to hit your fastest time with your setup then you cant go wrong with ss2.
also if you do decide to run aftermarket cams and it has bold huge words saying run its aftermarket valve train, you better do it… unless your an engineer and can determine ur stock valvetrain can handle additional stress from the lift without snapping the spring or close the valve fast enough, cause if it cant do that then youll be wasting your time no?
Acura USDM 98-01/JDM 96-01 ITR Valve Springs
Variable or Linear: Linear
Seat Pressure: 50lbs
Max Lift: 11.5mm
Coil Bind: 11.7mm
Pressure @ 11.5mm/.453" lift: 150lbs
just thought i would throw that in there…
[QUOTE=unified112;2231404]Designed/Intended RPM range isnt the end-all/be-all when deciding which springs to run…
edit
And a stock non-knife-edged crank can run 10k rpm without issues of reliability… as you said, its moreso the bottom end fasteners (and possibly the installation of a girdle) that need to be worked over.[/QUOTE]
[QUOTE=tilegend;2232766]Acura USDM 98-01/JDM 96-01 ITR Valve Springs
Max Lift: 11.5mm
Coil Bind: 11.7mm
just thought i would throw that in there…[/QUOTE]
boom :rockon:
I just want to comment on coil-bind from a more theoretical standpoint. Coil bind is more likely to occur with springs that have a short period (i.e. more rotations/windings). Given two springs of the same length and spring wire diameter, but different number of windings. The spring with more windings is more likely to bind. This is because it will have a smaller maximum compression length. If you exceed the maximum compression length, essentially you are compressing the spring to the point where the coils of the spring make contact with each other… this is what causes binding.
This explains why you often see race springs that will have a smaller number of windings, as it allows for a larger maximum compression length (less likely to bind with higher lift cams). There is a trade-off with springs with less windings though. A smaller number of windings means that the coils of the spring will operate at higher frequencies (i.e. each coil will have to travel farther distances), which will make the spring more likely to fail from material fatigue.
Summary:
less spring windings/rotations = higher maximum compression length (higher POSSIBLE lift) but also higher fail rate caused by metal fatigue.
Why go pro series when you could go tuner series and still rock stock pistons. I think its really what your looking for.
