Sparco Evo Competition Evo Seats
Well although I never had to long to sit in them. Only a half hour, I must say that these are quite comfortable even though the are a one piece on adjustabel design.
This set was in an EG Civic Hatch, you seat quite low to the floor but are held frimly in place by the seat and the harness (5 point, which is what I recommend using).
The only thing that bugged me is they are a bit hard to get in and out off. It’s a fit getting in but once in their seem to be few problems.
I think these seats are very good however I would have liked to be able to sit in them for longer.
you got a sparco evo seat in your g2? do you have power seat belts? did you disconnect them or still have them running? I am planning on getting some sparcos as well and getting a 5 point harness but I have power belts and don’t know about turning them off. what did you do?
With the seat in place, and the 5 point harness, just remove all of the power belt components…
The grey box under the dash on the passenger side, discontect … that will stop all power going to the belts, and stop the annoying beep beep when they are removed…
That is what I did, with the sparco evo2 seat and 5point…
But if you are just doing the seat and harness for looks and have nothing to bolt it up to , I recomend that you leave you stock seatbelts intact…
there was another thread around here about that…
This was in my friends car, not mine.
Also only USDM G2s had power seat belts. CDM G2s have normal ones.
