Spectra Premium Radiator CU292
help!
I just bought this Radiator and took my Toyo one out… I can’t fit the AC fan and the Regular fan on…
Do i have to get another one? I’m from Winnipeg Canada… but my car is from New York US.
the radiator i bought is a replacement part… the brackets for the lower part of each fan do not match… can someone help me out on what to do…??
Thanks
Have you verified that the model # on the radiator is the same as the model # that is designed for 90-93 Integras? It’s possible you have the wrong one. If not, pictures would help.
You should update your location, by the way.
Toyo 19010PR3024
I know for a fact that it is a Toyo 19010PR3024… I’m limited to where i can get these parts in Canada… all the shops in Winnipeg keep giving me the Spectra CU292 as the replacement… (and I’m getting really Annoyed because the parts guys give me a hard time cuz i tell them that’s not what i need). I know for sure that it doesn’t fit my AC fans… and the aluminum is thicker then my stock one…
Does anybody know where i can get a Koyo or a Toyo one in Canada?.. I’ve seen the pictures of the Koyo it looks exactly the same as the Toyo one…
I’ve emailed Koyo in the states and I’m waiting for a quote on price and shipping… I have this feeling its going to be expensive…
One more question… on the stock Toyo Rads… my top part of the rad is cracked and its been leaking that’s the reason I’m replacing it… is the top part and bottom part plastic? if it is… is it possible to just epoxy it??? I’m thinking i can’t cuz of the extreme weather we have in Canada… LOL
If anybody can help me it would be appreciated thank you…
Have you tried Ebay or on here? There are some vendors on here that sell aftermarket radiaitors if im not mistaken.
i’ve checked ebay… but i’ll check here too… thanks
Do not use an epoxy or adhesive to fix your old radiator, you don’t want foreign chemicals polluting your coolant and getting into your lines. It will eventually crack back open anyways, not something you want to have happen.
Yes, there are several vendors that will sell aftermarket radiators, but be prepared for the shipping charge as most of them will not have a warehouse in Canada. Hope you get it figured out soon :slight_smile:
[QUOTE=oneoffG2;2074150]Do not use an epoxy or adhesive to fix your old radiator, you don’t want foreign chemicals polluting your coolant and getting into your lines. It will eventually crack back open anyways, not something you want to have happen.
Yes, there are several vendors that will sell aftermarket radiators, but be prepared for the shipping charge as most of them will not have a warehouse in Canada. Hope you get it figured out soon :)[/QUOTE]
Thanks man… i’m trying to look for one in town first… don’t wanna pay the shipping cost… lol…
thanks all
