SPFAB 2'' Radiator Installation- How did you do it?
So I got my SPFab Half Size radiator in the mail. Working on installing it. Of course, it’s not a direct fit (wasn’t technically made for a DA integra)
The main issue is mounting location. It sits on top of the front crossmember causing it to be too tall for the hood to clear. So what did those of you with this radiator do to make it fit? Beat the crap out of the crossmember?
Just trying to decide on options for fitment. (Not sure if it matters, but I no longer have an A/C compressor or a power steering pump)
:werd:
i cut some of the hood out from the inside to fit my half rad.
here’s a pic of what i took out while i was finalizing it.
i would not beat on the crossmember under any circumstance.
ive seen people crack them after a few heavy corners. dangerous.
cutting the hood is the quickest way. if you wanted you could have brackets made that mount the radiator down and towards the engine more, kinda sitting against the crossmember instead of sitting on top of it.
my boy has a ridiculous turbo setup and has to run a half core, we just made brackets out of some scrap box steel and that was almost 30k (abused) miles ago. car has been through two motors, blowing a hole in one and pinging a piece of a conrod into the radiator… and the mounts havent failed.
Yea lol I wasn’t exactly planning on beating in the crossmember. It’s ugly enough as it is :smiley:
I’m just gonna have brackets made up on top and bottom. Don’t feel like cutting the hood, just not my thing.
While I would not recommend hacking up your front crossmember, I have seen a DA front crossmember from a purpose built track car which had been “swiss cheesed”. It had been cut as much as possible to make it lighter and still seemed to hold up fine. It looked scary as hell and I wouldn’t do it on my car… but it seemed to work for the OP.
My recommendation would be:
  1. Cut/notch/box the stock crossmember to allow the radiator to drop down. As long as you have some common sense regarding fabrication and know how to weld you should be able to modify the stock piece to be strong and provide a better mounting location for the radiator.
  2. Purchase an aftermarket crossmember and fab your own lower mounts for the radiator.
I’ve also seen people angle their radiators back in order to gain a little bit of vertical clearance.
