I drive a 91 integra db1, its a b18a1. the car runs fine while im driving but, when i come to a stop like at a stop sign or stop light the cars idle drops from 600 down to about 200 and then dies. i cant figure out whats wrong with it. the spark plugs,wires, and distributer have all been replaced. i checked my plugs the other day and the number 4 plug had some oil on it, i cleaned it off and recapped all of then and it ran fine for alittle hile but then it started dying again everytime i come to a stop. please help, thanks
did you try cleaning your iacv… check here
also check the teg tips section for idle related stuff, there is a lot
thanks, ill clean the iacv out tomorrow and see if it helps, sounds like it should do the job
ok i cleaned the iacv today and it didnt help. the car still wants to die everytime i come to a stop. it idles fine when im just sitting in my driveway but after i start driving it stats acting up
Is your car an automatic or a manual?
Put the car in neutral and throttle up the RPM to 1000 to 1500 for about
30 seconds. Let go of the throttle quickly. Does it happen the same?
Have you changed the fuel filter? Checked the Throttle Position Sensor?
I also suspect the car’s throttle body is probably super dirty and or surrounding that deals with idling /vacuum leaks.
First let us know what you have tried…
its a manual transmission. the car ran good today didnt act up once, maybe cleaning that iacv yesterday actually did help. when i rev it up to 1500 and hold it for 30 seconds and release the rpms drop to about 350-400 and then after about a second or two it goes back up to 500-550. is 500 to low of an idle speed?
There is an idler screw on the throttle body. Normally it does not need to be adjusted at all as it is set from factory, but i suppose as time car ages etc.
You can adjust it by turning with a flat head screwdriver counter clockwise as engine is idling. You want to turn it until it sits around 700-850rpm. it is up to u, but i figured if u set it at 800-850rpm you will never have a problem with the low idle again. also check and clean throttebody inside where the intake air goes probably very dirty sticky too.
on my hood it has a label saying 750 - or + 50 so around 700-850rpm is good. 500 to me is very low as for when car is old when turning on lights and other things it tends to go even lower so if u want up it. shoot if it was me setting it at 900-1000 wont hurt at all as i like it a lil high.
best of luck
i ajusted the ide screw and its now around 900. i took the intake pipe off the throttle body and it had what looked like oil in it. same with the throttle body itself, i didnt take it off but i looking inside and it was really dirty. its all clean now and hopefully everything will run right, thanks for the help
yea overtime oil fumes gets pass and reuse to keep the air clean. those oil, fume etc comes from that tube/hose that connects from your valve cover to ur intake arm.
Anyway it should be good now because if you dont notice any drop more than 400rpm in idle from a stop then its good. also some people may still get it slightly only when they brake really hard coming to a stop not sure why…
To clean the inside out really good is to remove it. otherwise your best choice is injector cleaner spray without the straw as it can fly into the manifold if u are revving it and cleaning it. dont overspray just dpray enough all around and then let it idle out again before spraying more.
Ok so far the car hasnt had anymore problems, which is great but, since i ajusted the idle screw up to idle at 900, every once and awhile the car acts like its breathing and the idle bobs between 900-1300. it doeant affect the way it runs or anything it just seems alittle weird. it only does it for a few seconds and then levels back off at 900. anyone know what would be cauing this? (remember i just cleaned the iacv)
usually when my fans come on when im sitting at a light or turn on my blower, the idle jumps a little.
ok problems have started again =[. the car is still trying to die when i start moving from a stop, even though the idle is set at 900. the idle is still fluctuating bewteen 500-1300 up and down pretty fast. the car is what i would call “bogging,choking,jerking” and then catching itself and continuing to run fine. when i messed with the idle screw is when it started those fluctuations. is there any other way to adjust the idle (throttle cable? maybe)
It is very complicated to tackle down hunting idles and what not. Some people never get it fix as they have or try everything and just dont got the money to do or time anymore.
I can tell you that there is a 2 pin plug of that IACV in the back and if ur car is idling and u unplug that while it is sitting at idle hunting i would bet it would stop. How many miles on the car now? When you clean the IACV did you completely remove it to do it also waht about the FITV did u take that out and check or screw down the white thing? i am sure one of those is out of spec or all i can say is u have a cracked hoses or something like that to leak so ur idle hunts. Also please check and if need tighten the intake manifold bolt down if its old gasket and air may leak sip thru etc. ur problem has to be within the hoses crack leak, gasket old leaking thru, throttle body very dirty as u didnt remove it to clean, TPS out of spec and whatever else related.
I can tell you right now if i keep switching my ecu chip back to stock and not resetting it correct and after driving hard and coming to a stop stupid idle will hunt from 800-1500 up and down no matter what until i reset ecu and or remove it an such. I been using custom chip to run my car and for smog i put it back in stock and warm car and take it in and it doesnt bounce.
the car has 183,xxx miles on it. when i got it alittle more then a year ago it only had 163,xxx. i did take the iacv comeplety off when i cleaned it (pain in the ass to do) what is the fitv? the thorttle body was kinda dity, but i did clean it (without removing it) i looked into the intake manifold and it looks bad, really grimmy and coated with black gunk. ive been having this problem for awhile now and im really sick of it. it seems to run fine with alot of gas, but as soon as it hits half a tank the problems begin. back in feb someone poured antifreeze into my gas tank, i didnt know it was in there so everytime i started the car it died. could that still be making these problems?
The antifreeze most likley had somthing to do with it. what i would do is test your iac by unplugging it and driving it all the iac does is make the idle drop slowly when you shift from gear to gear your car should run perfecly fine with it unplugged or with a block off plate. If this solves your problem buy a new iac and you should be gold. it wouldnt be a bad idea to seafoam your motor it works wonders and will clean out everything in your motor.
For me unplugging the IACV and let it idle is fine but driving it will bounce up and down so its a no go… Dont know how u say unplug it and will help. Check CEL will throw.
Same thing if u using a plate it is about same as using a type r tb or something without the fast idle valve. FITV i think is the one that controls ur high cold fast idle to warm car up then it shuts. if its not shutting all the way u will have hunting idle like 800-1200 etc. its been talked about too…
Thats been my experience with my other car it war acting up so i unplugged it and the idle whent normal but fell really fast when i would shift and it did throw a cel i thought it would be worth a try
yea i unpluged it and drove it around the block once. it idled really low at like 200 and the cel was on the whole time. i plugged it back in and the idle seems to be doing just fine now. maybe it was a loose connection.
I doubt it fixed your problem. It is funny how things react though. Now you unplug it and now plugged it back and its fine. Well just keep us posted on whatever you do or plan to fix in near future ok.
If i were you if your state smog isnt a problem I would get the ecu socketed and then get a stock or performance chip burn for it so you can then get the idle you want and not ever worry about hunting and others.
