ok i put a new clutch and a flywheel on my car but know wen i start my car the starter make a noise like if i would be holding the key too much…i wanna know why is doing that…:think:
is the starter bolted in correctly? what clutch/flywheel did you use?
fidanza one 9 pounds…
have you had the starter out?
no…
I would still check to make sure the bolts are tight
does it sound like the motor inside the starter is just spinning (kinda like a drill on steroids)
or does it make a griding noise…
[QUOTE=tilegend;1849215]does it sound like the motor inside the starter is just spinning (kinda like a drill on steroids)
or does it make a griding noise…[/QUOTE]
grinding noise
